Dimmer on a dimmer?
Old 10-05-19, 09:33 AM
G
Dimmer on a dimmer?
Hi there... I have two new wall mounted lights which each have their own built-in dimmer switches. I would like to use them permanently switched full on - and then both controlled from a single wall dimmer switch. Is that ok? Will it work? The wall dimmer is already wired and working to the existing wall lights in place. Thank you.
Old 10-05-19, 09:35 AM
Received 3,753 Upvotes on 3,365 Posts
Good question. Give it a try. I doubt you'd hurt any of the dimmers.
Old 10-06-19, 10:46 AM
G
Thanks Pete - I think I'll give it a try!
