3 way switch trouble shooting: No continuity in the traveler wire
Old 10-20-19, 07:05 PM
Received 2 Upvotes on 2 Posts
Hello,
I have a set up with a 3 way switch (A) and a dimmer (B) controlling hallway lights (see attached picture).
The switches were working fine both ways (as a three way should), till recently. As the light would not turn on, I thought the dimmer must have quit working, so I replaced the dimmer. HOWEVER, now the dimmer only works if the switch A is in ON position.
I tried troubleshooting the wires. Switch A has a live wire in the black screw position. The two travelers go to the dimmer in a separate cable, and are attached to the traveler wires of the dimmer.
The problem is one of the travelers does NOT carry current or show continuity (the other one does). I do not see any obvious splice or nick in the switch boxes at either end. No other work or repair was done in our home recently.
Any idea why this is happening or what it means?
Appreciate your time to read and reply
JK
(the attached pics was customized by me, based on examples shown by moderater Ray2047, so credit to him for the wiring diagram)
Old 10-20-19, 07:34 PM
Received 516 Upvotes on 421 Posts
Did you try flipping the other switch to see what happens? The voltage should flip between the travellers when you flip the other switch.
