Switched Outlet at end of three way switch ?
Hi again,
I want to add an outlet to a small wing wall that operates on a 3 way switch. The power goes into the first switch box at start of the run (14-2) then from seitch box 1 to switch box 2 i ran a 14-3 wire, just like a regular 3 way switch set up i used before.
Am i right in thinking i can just run a 14-2 wire to the outlet box from switch box 2 the same way i would if i were connecting a light fixture? Am i missing anything here?
If i need to wire it differntly please post a diagram if you have it. I can fairly easily pull the power in line back to the outlet box instead of the first switch box but rather not have to do that.
