ceiling fan w/ light kit install
Old 11-12-19, 06:08 PM
B
Does the red wire attach to the black wire to use the wall switch? I have black to black, white to white, green w/bare... red wire left over... everything works with remote but it wired to light switch... red wire not hooked up yet... thanks
Old 11-12-19, 06:20 PM
Received 3,983 Upvotes on 3,575 Posts
Welcome to the forums.
You have two hot wires...... red and black. One is switched and one is always live. You'll know which one you've used based on if the wall switch works. You will use the one that operates the way you want and cap the other off. Typically if the fan has a remote..... it gets wires always live.
beernutz2 voted this post useful.
Old 11-12-19, 06:28 PM
B
Thankyou so much.. That works!!
