can bulbs be replaced in these recessed downlights?
Old 11-14-19, 05:24 PM
Received 1 Upvote on 1 Post
A light went out in the basement. I removed the light fixture to discover a foreign looking recessed light. It's a slim profile recessed downlight (only 1/2" thin). The back has 6 screws on it to access the internals, however, I'm not even sure if the bulb inside can be replaced. A replacement looks expensive online ($75). Do I bother opening it or does the whole thing have to be replaced? Thanks.
Link below to light model
​​​​​​https://www.liteline.com/20000067-ma...4/slim-classic
Old 11-15-19, 12:08 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
It would not have a conventional bulb since LED, did you call the manufacturer or supplier?
Shepweiler voted this post useful.
Old 11-15-19, 04:21 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi, have you tried another light in that fixture to be sure itís not the power supply, you could also test that supply cord to be sure there is 33 VDC present.
Geo
Old 11-15-19, 07:11 AM
I did test the bulb in another power supply and it works. So I think the problem is the LED driver and not the bulb. Thanks.
