How to remove a gas pipe ceiling fixture.
Old 11-17-19, 12:11 PM
I want to mount a modern lighting fixture or fan where a gaslight + knob and tube fixture was located. The gas and electrical are not active. A short section of pipe extends beyond the ceiling into the room. The pipe is up against a joist and I believe it is attached to the joist. I tried freeing it with a 12" pipe wrench.
What is the best way to remove it? Should I just use a longer wrench?
Do I need to remove it? Can I mount a fan box to the pipe?
Picture of the ceiling fixture.
Old 11-17-19, 12:55 PM
Received 416 Votes on 389 Posts
I would make the hole slightly larger and find the joist. They make boxes that fasten to the bottom of a joist or directly to the side. One of those may work there. The pipe may not be in the way. Some box choices below.
Old 11-17-19, 02:29 PM
Received 96 Votes on 88 Posts
It may not even be a gas pipe. It could be an old fixture mount.
Old 11-17-19, 04:57 PM
Norm201's Avatar
Received 91 Votes on 83 Posts
If it's in the way you can use a cut off saw and cut it off level with ceiling. If it's solid and does not move or vibrate you could as JOED suggested use it as a fixture mount.
Old 11-17-19, 09:41 PM
I'm not suggesting to USE it now. I am suggesting it may have been used in the past for the K&T fixture with no box. It could also be an actual old gas pipe.
Old 11-18-19, 05:18 AM
Geochurchi's Avatar
Received 19 Votes on 19 Posts
Hi, was there a black cast iron box there originally? Is it threaded, push a wire into and see if you can determine if there is an elbow a short way up , if so I might get a longer wrench. Your lucky, I have found them live with gas.
Geo
Old 11-18-19, 11:48 AM
Depending on the type of fan you are installing..... the gas pipe may be able to be left there.
Many ceiling hugger type fans have a 12"-16" canopy that can cover a large area.
Old 11-18-19, 08:58 PM
It hadn't been discussed...... do you have a way of getting a new cable there for power ?
Old 11-19-19, 01:51 PM
Received 24 Votes on 24 Posts
You need to be sure that the pipe is mounted securely enough to support the new fan before trying to use it as a support..
Old 11-19-19, 06:06 PM
No..... you would not use the pipe to hang a fan or light from.
geo8rge voted this post useful.
Old 11-21-19, 11:09 AM
Thanks everyone for the replies. Am I allowed to extend the pipe through one of the knockouts in the pancake box? Any holes in the ceiling would be plastered, but the pipe would still extend through the plaster into the box?
Old 11-22-19, 09:50 AM
I don't see a problem allowing the pipe to enter the back of the box. That would mean you are surface mounting the pancake box. That sure doesn't leave much room for connections.
Old 11-22-19, 02:10 PM
Thanks for all the help. Using a pipe to extend my largest pipe wrench freed the pipe. It turns out doubling the length of the lever really does double the torque, and even made working from a ladder safer. Just make sure you're doing lefty loosey, not righty tighty.
