Weird outdoor light bulb
Old 11-22-19, 05:32 PM
R
Hi,
I'm a sort of new homeowner (less than 5 years) and have been slowly learning how to do things a little at a time. Our house was built in about 1955. I tried to change one of the outside light bulbs today and after the fresh bulb wouldn't screw into the socket I looked at the one I had just removed and it had a base I had never seen before. A google search turned up nothing. Nothing is written on the bulb.
Here is a picture of the light bulb. What is this? Where do I get them?
Old 11-22-19, 05:34 PM
XSleeper's Avatar
Received 1,900 Upvotes on 1,706 Posts
The inside of your fixture broke off and stayed threaded onto the bulb. So I'd say that fixture is ruined. It's a normal light bulb.
Ravens Starr voted this post useful.
Old 11-22-19, 05:39 PM
R
Thanks! I was wondering if that could be it but I have no clue about these things. My next step will be figuring out how to remove it without killing myself
Old 11-23-19, 04:55 AM
Norm201's Avatar
Received 716 Upvotes on 637 Posts
Turn off the power to that fixture at the switch and the circuit or fuse box. Remove fixture, then using a test light or VOM, check for current at the connections. Then and only then do you want to touch the bare wires.
In many of these older homes it not unusual to find two sets of live circuits to be contained in one fixture.
Old 11-23-19, 05:02 AM
P
Received 2,108 Upvotes on 1,887 Posts
Replacement sockets can be found at many home centers or ordered online so you might be able to fix your fixture.
