Antique Lamps
Old 11-23-19, 02:10 PM
D
Antique Lamps
I have 3 antique lamps that I want to wire together in order to place on a book shelf so that the wiring is unobtrusive. Each lamp is currently wired separately. Photo attached.
Thanks
Old 11-23-19, 03:28 PM
P
Received 2,009 Upvotes on 1,801 Posts
So, do you have a question?
Do you want to hard wire them together to one plug?
Are you going to use a power strip or multi-socket extension cord?
Old 11-23-19, 04:45 PM
Shadeladie's Avatar
Super Moderator
Received 370 Upvotes on 299 Posts
I get they want to wire them together as one but want the wires somewhat hidden, so you don’t see a bunch of wires showing as you see them now.
Old 11-23-19, 04:50 PM
XSleeper's Avatar
Received 1,839 Upvotes on 1,654 Posts
Mount them on a board that will conceal the wiring underneath.
Norm201 voted this post useful.
Old 11-24-19, 10:53 AM
D
Sorry, yes I am looking to wire them together and then be able to plug into the nearest receptacle. I will rewire with white cable to match the bookshelves. I appreciate your attention!
Old 11-24-19, 10:59 AM
P
So do you need help figuring out how to wire them together? Are you comfortable soldering or do you want to use a terminal strip or wire nuts?
Old 11-24-19, 12:02 PM
D
I would prefer to use wire nuts
Old 11-24-19, 01:03 PM
Received 501 Upvotes on 411 Posts
You can't have open connections. They need to be within the lamp or a junction box.
I would put a separate cord on each lamp and plug into a splitter.
