Flush mount fixtures
Old 11-25-19, 11:24 AM
G
Got a second hand light fixture. Is it okay to use regular pink insulation for this flush mount fixture. In new fixtures I believe I have only seen a yellow type of insulation
Old 11-25-19, 03:54 PM
P
Received 2,101 Upvotes on 1,881 Posts
Pink is the trademarked color of Owens Corning insulation. It's basically the same as other fiberglass insulation and can be used interchangeably. The color doesn't matter. Just make sure you use fiberglass only. No backing material.
Old 11-25-19, 04:07 PM
Received 3,877 Upvotes on 3,475 Posts
The insulation is required when using two or more 60w incandescent lamps.
If you switch over to LED.... there will be a lot less heat.
