Help replacing Switches
Old 12-04-19, 07:43 PM
I
]I have these switches in all my bedrooms and want to replace them with square plugs. House was built in 1995. Iím assuming these are using a two gang box and Iíll need to replace them with a three gang box. Curious to know what these switches are called and if I can replace them. Thanks in advance.
Old 12-04-19, 08:07 PM
Received 4,089 Upvotes on 3,672 Posts
On the left is a dual or duplex toggle switch.
Square plugs ?? What is a square plug ?
Do you mean a Decora duplex switch left in the picture.
Or three standard Decora switches.... right in the picture.
Three standard switches would require a three gang box.
BE SURE to take pictures of your wiring before disconnecting the old switches.
Old 12-04-19, 08:12 PM
I
Yeah I didnít know square plugs had a name but you found it . Now if I wanted to separate the two so there are separate switches, three individual switches. Would I need to expand the electrical box?
Old 12-04-19, 08:28 PM
Yes..... you would need to replace your two gang box with a three gang box.
It's not always as easy as it looks.
Take the switches out without un-wiring them and see what type of box you have.
Old 12-05-19, 04:02 AM
A
Received 171 Upvotes on 141 Posts
PJmax: I think maybe your autocorrect made a change.
"Take the switches out with un-wiring them"
I think you meant to say take the switches out without un-wiring them. Am I correct?
Old 12-05-19, 04:06 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Pictures.Pictures PICTURES I think your correction was right.
Old 12-05-19, 08:37 AM
I
Thanks everyone for the help. You have really helped out me out and I know how to proceed. Thanks.
