3 pole rocker
Old 12-19-19, 07:22 PM
K
3 pole rocker
How to install a 3 pole rocker 12/2 coming in and 14/3 going out to the switch poles and ceiling fan box?
Old 12-19-19, 07:47 PM
Received 3,416 Upvotes on 3,063 Posts
Welcome to the forums.
If that 12/2 is on a 20A circuit....... you'll need to use 12/3 to the fan.
What is a 3 pole rocker ? Do you have a link to it ?
Old 12-20-19, 05:25 AM
Norm201's Avatar
Received 667 Upvotes on 590 Posts
I suspect they mean a 3 pole rocker switch.
Old 12-20-19, 04:02 PM
Ok...... but what is a 3 pole rocker switch. A common input switch to three separate loads ?
If that is the case......
The white wires get joined together.
The black wire from the two wire cable goes to the common of the switch.
The red of the three wire goes to one switch.
The black if the three wire goes to another switch.
Old 12-23-19, 11:21 AM
K
Thx PJMax, so with me using 12/2 coming in and 14/3 going out it wont work right ?
Old 12-23-19, 11:33 AM
It will work but what is the circuit protected at..... what breaker size ?
Old 12-30-19, 01:09 AM
K
20amp breaker
20amp circuit breaker for the switch
Old 12-30-19, 04:19 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, a 20 Amp circuit breaker for the 12/2 then you need 12/3 to the fan.
Geo
Old 12-30-19, 06:04 PM
K
20amp
So it will not work with 14/3, but it comes on when I connect the blk/blu together, not trying to be a smart pants just trying to figure out, didn't kno different type of wires for lights matter !
Old 12-31-19, 10:36 PM
When you install house wiring...... it must be protected. The wire size determines the breaker size. You have #12 wiring that requires 20A breaker. #14 wiring would be protected by a 15A breaker.
If you use two different sized wiring..... the breaker matches the smallest sized wiring.
Now.... for us to help you with the switch..... we will need a make and model number of it OR an internet link to it OR a picture of it. How-to-insert-pictures.
