remove halo h99ict housing
Old 12-26-19, 10:10 AM
K
I need to remove halo h99ict can light housing so I can access the wiring to add another light in the same room. How do I remove the housing?
Old 12-26-19, 11:35 AM
Received 3,423 Upvotes on 3,069 Posts
Welcome to the forums.
If there are no visible screws in the can then the can gets pulled straight down.
The most common method is shown in this video.....
Halo can removal
Old 10-24-20, 09:38 PM
If you can't just pull it down
I work as an electrician, and have for several years, and some cans just wont pull down. The best alternative is to get a flat blade screwdriver, stick it between the the housing and the outside casing, and bend back the three tabs holding it up. After you will have to take a pair of lineman pliers and gently bend back the dent.
