Ceiling light
Old 01-07-20, 08:23 AM
Ceiling light
Hi everyone.
I'm trying to replace ceiling lights in my living room. There are two lights and one switch with two little switches for each light.
So when I took the old lamps off, from one of the holes there are 3 sets of blue, brown and green wires. And the other one 2 sets. But on my lamps there are just 3 holes L, N and one for the green wire. Do I just put them all together? So one of the lamps would have 3 brown, 3 blue and 3 green wires going to it and the other one would have 2 sets of each? Is that normal?
Old 01-07-20, 09:12 AM
Received 259 Upvotes on 232 Posts
Sorry but I find your description very confusing!!!
Perhaps some pictures would help.
What I can tell you is that Blue is Neutral, Brown is line (voltage) and Green is ground.
Old 01-07-20, 09:24 AM
Received 1,190 Upvotes on 1,147 Posts
How was everything hooked up on the old fixtures?
Old 01-07-20, 09:29 AM
P
Received 1,766 Upvotes on 1,579 Posts
"...one switch with two little switches for each light..." Is this correct??? I'm afraid you'll have to give us a picture as I have never seen one switch that has two little switches on it. It is possible that you have a switch and a slider/dimmer?
Old 01-07-20, 09:30 AM
Sorry I've tried adding pictures and links and its not working for some reason.
It's just a basic light switch but operates 2 separate lights in the same room.
So I've took off both light fixtures and ceiling roses and got exposed wires coming out from the ceiling. The first hole has 3 sets of wires - 3 blue, 3 green and 3 brown. The second hole has 2 sets of wires.
I'm gonna try again to add some photos.
Old 01-07-20, 10:09 AM
I'm sorry I'm trying upload pics, I've got url but it's not working
Old 01-07-20, 10:50 AM
By the sound of it you are in Europe as your wire colors are not North American.
I do not know how they do things in Europe.
Here when you take a light off there is a metal connection box that the fixture mounts to and the connections from the house wiring to the fixture wiring are done.
