Wall wiring too short
Old 01-19-20, 12:04 PM
K
I'm not sure how to lengthen the wires in the wall too replace the receptacle. This outlet is connected too all of the outlets in the kitchen. Nothing works. Help!!! The house is 60 years old. I've updated wiring in the new edition, contractor never checked the wiring in the kitchen or living room. How do I fix this? I've installed fixtures, receptacles. I'm not sure how too lengthen the wall wires.
Old 01-19-20, 12:50 PM
Received 477 Upvotes on 393 Posts
You can't lengthen wires. There is no such thing as a wire stretcher. You need to move the box closer or replace the cable.
Old 01-19-20, 01:10 PM
K
Thanks, I figured that, I just wanted to make sure.
Old 01-19-20, 04:23 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, where are the wires are you trying to lengthen? Post a pic of the box in question.
Geo
Old 01-19-20, 05:03 PM
Z
Received 367 Upvotes on 327 Posts
If you have an inch or so in the box, you can use a wire nut and pigtail the wires to make them long enough to connect to the receptacles. Will that work?
CasualJoe voted this post useful.
Old 01-19-20, 05:43 PM
Received 1,190 Upvotes on 1,147 Posts
If you have the access, sometimes adding another junction box allows the cable to be spliced.
Old 01-20-20, 05:51 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
The wires can be lengthened. Try using these Ideal Term-A-Nut pigtail connectors.
Ideal Term-a-Nut Twist-on Pigtail with 6 Inch Wire MultiPak - Spade / Ring Terminals - Ideal 30-3181 - Sandman-Store.com
