Replacing regular light box with ceiling fan support
Old 01-20-20, 11:33 AM
P
Received 1 Upvote on 1 Post
So I'm trying to replace the standard light fixture in my bedroom with a ceiling fan, and I'm not sure how to replace the box with one strong enough for a ceiling fan. Up in the attic, I got a couple pictures of the current box. It's nailed to a horizontal truss support, but it's also wedged under a 2x4 that is braced across the trusses. See pictures. Should I get a metal box that I can just screw right into that cross brace? Or cur out that brace out and screw a new box to the side of the horizontal truss bottom? Not sure how best to do this. And man there is not much room up there to work.
<img src="https://i.imgur.com/UJyi8eS.jpg" width="4032" height="3024"/>
<img src="https://i.imgur.com/MjJo970.jpg" width="4032" height="3024"/>
Old 01-20-20, 05:51 PM
Tolyn Ironhand's Avatar
Received 882 Upvotes on 745 Posts
I suggest removing the existing box and replacing it with a steel 2 1/8" fan rated box. You should be able to screw it directly to the 2 x 4
Old 01-21-20, 03:03 PM
P
Thanks. Yeah I ended up taking a Sawzall to that 2x4 brace there, I couldn't get the old box out with it there. Then I got a metal fan rated box with the side mount and screwed it into the bottom of the truss. Seems pretty solid. Thanks for the input.
