Replacing Light Switches
Old 02-07-20, 06:43 AM
I am going through the house and changing all light switches. My house is wired with 12 gauge wires. Most of the switches in the house have more than two wires, 2 are usually on the screws and a couple plugged into the holes on the back of the switch. Unfortunately all the switches that I have found for sale are only fit for 14 gauge wire. What is the solution to this?
Old 02-07-20, 07:17 AM
Received 259 Upvotes on 232 Posts
Do not use the backstabs.
They are not known for their reliability over the long term in any case.
So you get wire nuts and use pigtails.
Old 02-07-20, 08:10 AM
Received 477 Upvotes on 393 Posts
Use pigtails to combine the wires into one wire for the screw.
Old 02-07-20, 08:02 PM
A
Received 251 Upvotes on 231 Posts
The screw terminals on the side will accept the 12 gauge wires.
Old 02-08-20, 10:09 AM
How do you know which wires can how together?
Old 02-08-20, 10:16 AM
Received 3,422 Upvotes on 3,068 Posts
There are four connections on a switch. Two screw terminals and two push-in terminals.
There is a push-in near each screw terminal. That is one connection. Those two wires can be combined into one.
