Replacing wall light switches
Hello,
I am starting up a home project to replace about 30 wall switches in my home. I am replacing switches that run on various lights and fans to rocker style switches. I know I need to match the wattage the light or fan takes with what the switch handles. Do I simply add up the wattage of the lights the switch would run on? Some switches turn on a single light, maybe 100 watts max. Other switches turn on multiple lights or a chandelier. Some turn on a bathroom ceiling fan. How do I figure out wattage for a bathroom fan? Would a fan say the wattage?
Thanks,
Paul
Thanks,
Paul
Welcome to the forums.
For the most part..... standard wall switches come in one rating. Typically for a 15A load.
There are 20A available for loads like disposers and heavy load appliances.
Dimmers are a different story. Although most handle 600 watts.... some are less depending on incandescent or CFL/LED operation.
A tip for you.
If any of your circuits are three way switches replace one switch and test it. It is much easier to fix a three way issue when you know only one of the switches is wrong.
