Convert Mercury Vapor HID light to outlet
Old 03-15-20, 10:52 AM
P
I have an exterior mercury vapor light above my back deck that I'm planning on replacing with string led lights.
If this were a regular e26 fixture, I'd simply get a socket to outlet adapter for the string lights to plug into. And I could do this by getting a e39 to e26 reducer first. But I'm concerned way the ballast would do it the system.
Am I right to be concerned?
Old 03-15-20, 11:00 AM
Received 3,880 Upvotes on 3,477 Posts
You would need to remove the fixture and replace it with a weatherproof receptacle.
Old 03-15-20, 11:12 AM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
Any exterior receptacle is required to have GFCI protection.
Old 03-15-20, 12:40 PM
Received 513 Upvotes on 418 Posts
You are correct. The transformer boosts the voltage for MV HID lamp. It would most likely burn up your LEDs.
Remove the fixture completely and replace with a box and receptacle after you verify the voltage. Some MV fixture are 240 volt.
