Switch with 2 black wires
Old 04-02-20, 11:30 AM
H
Received 2 Upvotes on 2 Posts
Went to replace an old, dead intermatic switch, bought a regular 3-way switch but it turned out the intermatic was a single pole set up for the patio lights. I tried using the 3-way switch with the two black wires one on each side on the brass terminals but still nothing. Should I just get a single pole switch and wire the black wires to each terminal? The white are pig tailed in the box.
This switch is in a box with another 3-way that controls the kitchen lights so it a tight squeeze.
thanks!
Old 04-02-20, 11:48 AM
Received 3,342 Upvotes on 3,001 Posts
You can use a three way switch as a single pole switch. Connect your wires to the black/dark screw and one of the brass screws. Depending on which brass screw you use..... the switch may be need to be turned for proper on/off direction.
Old 04-02-20, 12:46 PM
H
Ok so I have it wired wrong by going to the two brass screws. Will that cause any issues if I can’t get back to rewrite it until tomorrow? Other than it not working obviously.
Old 04-02-20, 12:56 PM
It won't cause any problems.
Old 04-02-20, 12:59 PM
H
Great thank you for your help I’ll switch them tomorrow!
