How 2 mount round base spotlight on single rectangular receptacle box?
Old 04-04-20, 03:06 AM
L
Replacing old single motion sensor spotlight with new double motion sensor spotlight on the exterior of my garage in an exposed area. Old mounting box is a single rectangular receptacle/gang box, mounted completely above the surface on a stuccoed masonry wall (not mounted flush inside the wall). Need to make it fit the round base of the new light. Have found about a hundred million faceplates and other mountings online converting a 4 inch round/octagon box into a single rectangle/gang box, but not the other way around. The search engines just absolutely will not give me that information.... No matter what I try, I get round to square mountings... Please inform. Or do I have to break down and just try and replace the rectangle box with an octagon?
Old 04-04-20, 05:36 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, can theses spot arms be removed from the plate and reinstalled on a rectangular plate? Post a pic of your fixtures, also another option would be to remove the existing and install the round box in its place, it should cover fine.
Geo
Old 04-04-20, 05:55 AM
Received 260 Upvotes on 233 Posts
You said it was surface mounted so just replace it with an octagon box.
