How to use GE ConstantColor™ CMH G12?
Old 04-10-20, 06:17 PM
Hong Zhang's Avatar
I have a GE ConstantColor™ CMH G12 lamp. I don't think my home has a socket for it. What is the easiest way to use it?
Old 04-10-20, 08:38 PM
Received 477 Upvotes on 393 Posts
You need a proper fixture with the proper ballast to drive that lamp. You can't just connect it to line voltage.
Hong Zhang voted this post useful.
Old 04-10-20, 09:20 PM
Hong Zhang's Avatar
Thank you. Can I buy the fixture from stores such as Home Depot? I did a lot of search before posting this question. I searched again a moment ago. I am unable to find anything that I can plug to an outlet to hold this lamp.
Old 04-11-20, 04:43 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, I would consider not using that lamp unless you have the proper fixture, it must be an enclosed fixture also.
Geo
Old 04-11-20, 07:18 AM
Hong Zhang's Avatar
Thank you. I will follow your advice.
Old 04-11-20, 11:43 AM
Received 3,420 Upvotes on 3,066 Posts
That is a fairly dedicated type bulb...... ceramic metal halide lamp.
It requires a ballast, starting capacitor, ceramic socket and an enclosed fixture.
It would probably more cost effective to purchase a new fixture with the lamp and keep that for a spare.
