LED BR40 flood light bulb won't fit in the can.
Old 05-05-20, 08:21 AM
A
Received 4 Upvotes on 2 Posts
I bought a Cree bulb from Home Depot. The light fixture is from the 60's and the three inside mounting bracket screw heads prevent the bulb from going in. A previous Kobi bulb fit fine but they are out of business. The Cree bulb is 129 mm across while the old bulb is 127 mm. Short of going to a bunch of lighting stores and measuring the bulbs, does anyone know what other brand would fit?
Old 05-05-20, 09:32 AM
Z
Received 422 Upvotes on 375 Posts
Can't help with a different brand, but they do make socket extenders. It'll add 3/4" or so so the bulb should fit.
https://www.homedepot.com/p/Halo-1-i...1999/100647410
Old 05-05-20, 12:11 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi, Will the socket move down in the fixture, sometimes there are screws inside that allow it to move, post a pic of the fixture.
Geo
Old 05-05-20, 10:03 PM
Received 3,982 Upvotes on 3,574 Posts
127mm = 5"
There are many choices of bulbs under 5" diameter. Check the list in the link.
1000 bulbs BR40 spec list
Zorfdt voted this post useful.
Old 05-06-20, 05:51 AM
A
Thanks, that's what I was looking for. Socket extenders would put the face of the bulb too far out.
Old 05-06-20, 05:17 PM
A
Went back to HD with a caliper and bought an Ecosmart 90WE bulb at 4.7". Fits perfect but not as bright as the Cree 120WE bulb.
Old 05-07-20, 11:14 AM
B
Received 5 Upvotes on 2 Posts
Track light bulbs with Rheostat - can you use LED?
We have some track lights - two sets with three cans on each track - that are hooked up to what I think it's likely a rheostat and not a more modern dimmer. The building was built probably in the early 80s.
The can calls for specifies R-40 or PAR 38 bulbs. 200w and 150w, respectively.
Can I use LED bulbs or should I stick with incandescent?
EDIT*** I meant this to be a new thread and accidentally posted it in this one. Sorry!
Old 05-07-20, 11:15 AM
A
Didn't think there was a choice, most places are not allowed to sell incandescent.
Old 05-07-20, 11:41 AM
B
Home Depot sells some incandescent. I tried a 5000k LED bulb we have in the can and it didn't seem very bright and had a little noise to it, making me think the rheostat was causing an issue? I didn't have it dimmed, it was on the max output.
Old 05-07-20, 12:07 PM
Geochurchi's Avatar
Hi, the brightness is determined by the Lumen output of the lamp.
Geo
