What Is This Plastic Part For? (inside light bulb)
Just curious. Can anyone come up with a socially redeeming value for this (once) circular white plastic part that was inside this LED lamp?
I didn't notice it until one day I saw this circular shadow on the bulb. It was from something rattling around inside.
I cut open the (plastic) bulb and extracted the plastic part which was brittle and broke into fragments. From its shape I judged that it was mounted more or less at the red oval I drew, concentric with but spaced about 3/4 inch from the LED assembly. (The yellow dots are the light emitting elements.)
(The lamp still works.)
How do I get rid of attachments made in error?
The plastic part in question does not appear to lend support but it was held in place by the LED assembly via two screws in the latter.
From the position I believe the plastic part occupied it appears to shadow, absorb, and waste a lot of the lumens that the lamp produces.
The frosted bulb also appears to absorb a lot of light output but that is another program.
The IT guys are in the process of changing the attachment system. After that it could be deleted.
from the position I believe the plastic part occupied it appears to shadow, absorb, and waste a lot of the lumens that the lamp produces.
Read the package the bulb came in or check the website for the manufacturer and model number.
I suspect it is there to diffuse the light better
Even the translucent bulb cover loses a significant amount of the light output, for the benefit of a softer, more spread light.
