Ceiling Fan Capacitor Question
Old 05-18-20, 04:36 AM
K
The attached photo shows the capacitor I'm replacing. I ordered the exact same capacitor (black) online and they sent me the gray one. They are both 4.5uF, but the original is 270WV.AC, and the gray one is 300V.AC. Is that a problem? or am I okay with what they sent me?
Old 05-18-20, 04:46 AM
Received 293 Upvotes on 263 Posts
Not a problem.................
Old 05-18-20, 05:20 AM
K
Thank you.............................
Old 05-18-20, 05:39 AM
B
Received 286 Upvotes on 254 Posts
Capacitors used in AC are normally rated in peak volts AC. Most AC voltmeters display RMS volts AC. You must divide the RMS reading by 0.707 to get the peak AC volts. So, whether your AC is powered by 120/240 RMS volts AC. the replacement capacitor voltage rating is adequate.
