Dayton 3 phase motor help
Skill set = I am not a licensed electrician but I am more advanced than your average home improvement guy/gal. I have wired a standard 3 phase outlet from a 3 pole panel so im not completely lost until I ran into this motor.
Got a large ventilation van for free and I need it and would like to use it so I cracked open the motor wiring case because this fan has never been wired and it has 9 wires... now im confused. They are all yellow and labeled 1-9. On the tag it says 208-220/440. I thought 208 was 3 phase and 220 was single phase 220? I dont have a transformer for 440 so thats out. Can someone point me in the right direction on which wires to use to get this thing going without telling me to hire an electrician. Yes I have a 3 phase box.
Thank you.
<img src="https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/606x385/m1_d365c8eb047c31936dfb255adce877c66c968573.jpg" width="606" height="385"/>
<img src="https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/601x404/m2_af9022101fa2bebae7b6f0460aaeeffea53eec3d.jpg" width="601" height="404"/>
Thank you.
Hi, how do you intend to control this motor? It will require overload protection as it does not appear to be thermally protected.
Geo
Geo
There are 208 volt three-phase wye and 240 volt three-phase Delta. There is also 240 volt single phase.
This motor is a three-phase motor and will require a phase converter. I would recommend looking at solid-state phase converters.
Hi Tolyn, OP states he has 3 phase available, must be an industrial or commercial location, no need for a converter.
Geo
Geo
Toyln Ironhand stated "240 single phase" that is why I questioned it. Thank you all for your replies.
Hi, post a pic of your supply panel, if you are not in a commercial/ industrial area it’s doubtful you have 3 phase.
Geo
Geo
Its up and running, Thanks for all the help and insight
I asked about single phase because where I wanted to install the fan is 30 meters from the panel and running 12/3 that far is more expensive.
