GU10 Bulb replacement
Want to replace halogen GU10's with some LED's .Condo were living in has several , the fixture both turns and tilts to aim bulbs . There's a retaining rig hold the bulb , i can pop the bulb up and out of it , but the base just turns and doesn't come down . I am at a loss , its probably so obvious.
<img src="https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/img_1788_b0c2e4f98f16588dcbe364f1a46f53976fef4e0f.jpg" width="360" height="480"/>
<img src="https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/img_1787_1171134299d2b7e0d250d1e828702845fbde2463.jpg" width="360" height="480"/>
<img src="https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/img_1786_0de8cf768602aee596b69757d5c4693c285904ed.jpg" width="360" height="480"/>
<img src="https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/640x480/img_1785_0468bd184de8b6342e231b8b063ba3c60105f1c0.jpg" width="360" height="480"/>
Hi, which base are you referring to? you say you can pull the bulb out, are you trying to remove the trim? use a utility knife or the like to cut the paint loose around it first.
Geo
Geo
Also those GU type lamps (bulbs) are a twist lock style. You have to turn it before you can pull it out of the socket.
You can use a sharp knife (sheetrock knife) to cut the caulk.
Remove the caulk, replace the bulb and recaulk.
