Wiring LEDs on my boat
Old 07-02-20, 07:06 PM
H
I wired up some 12v LED light strips on my boat today, but not luck getting them to work.
I went from the fuse box (FB) to a switch (S) to a number of branches with LED strips (L). Can anybody help me fix my mess?
Thanks!
<img src="https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_2148_483009ebf96c1420c72acb48e3dceaeec76af230.jpg" width="1128" height="1504"/>
Old 07-02-20, 07:56 PM
Received 477 Upvotes on 393 Posts
Wiring looks good.
Are the light DC rated?
Are they 12 volt rated?
Is the polarity correct?
Is there 12 volts coming out of the fuse box?
Old 07-02-20, 08:35 PM
H
Yes, 12v DC. All checks out.
And have 12v coming from fuse box. I confirmed that.
I was careful wiring + and - but maybe I’ll have to retrace the line.
Old 07-02-20, 08:37 PM
Received 3,415 Upvotes on 3,063 Posts
You confirmed you have the hot 12v. Maybe it's the ground you are missing.
Old 07-02-20, 10:15 PM
H
Used a multimeter on the fuse box hot and ground bus and got 12v. And have same reading going into the first LED strip —- but no light coming out!
Old 07-02-20, 10:35 PM
If you've confirmed 12vDC at the LED...... the problem is with the LED.
Possibly not a 12v product or 12vAC.
Can you leave a link to what you are using ?
Old 07-03-20, 04:20 AM
B
Received 234 Upvotes on 207 Posts
Need LED manufacturer and model number. LED array manufacturer's connect the single leds to form an array that will can operate from DC or AC voltage. If DC voltage, the connection is polarity sensitive. In your diagram, it appears the switch is opening/closing both voltage wires. Only the hot wire needs to be switched. Also recommend installing a fuse in the hot wire.
Old 07-06-20, 06:23 AM
H
Ok, here is a link to the LED lights
and here is a link to the Switch
I completely bypassed the switch, but no luck either.
Old 07-06-20, 06:26 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, those strings come in 12 or 24 VDC , are sure the ones you have are 12 VDC?
Geo
Old 07-06-20, 06:36 AM
Tolyn Ironhand's Avatar
Received 672 Upvotes on 570 Posts
How are you connecting the strip to the wires? Are you using some type of connector or soldering leads directly to the strip?
H
Good call. I just checked to confirm they are 12v.
Old 07-06-20, 06:39 AM
H
The connections were soldered.
Old 07-06-20, 07:01 AM
Geochurchi's Avatar
Hi, if you have confirmed they are the correct voltage, you have tested at the solder connection and confirmed the correct voltage then contact the supplier and see what they say , probably need replacement.
one thing you could try would be to isolate the strings and bring a supply to different ends and see what happens, could be a defective first string.
Geo
Old 07-06-20, 09:40 AM
B
Spec sheet limits LED strip length at 12 vdc to 10 meters and 24 vdc to 15 meters so strip length is a factor in the installation. They don't state if the strip length is per parallel branch or total because your diagram shows many parallel branches. Nor sure how to interpret the 18 or 36 LEDs/ft on the spec sheet as each LED element in the array drops 0.7 vdc when conducting so the LEDs/ft affects the vdc/meter restriction. One of the reviews following the specs indicate one of the part numbers has polarity reversed on the strip so be aware.
Old 07-06-20, 12:19 PM
H
Problem solved. As noted in the previous post, I tried switching polarity and BINGO.
Thank you all for your help.
Old 07-06-20, 02:25 PM
Geochurchi's Avatar
Thanks for letting us know, I bet that won’t again, lesson learned!
Geo
