Light switch plate not flush with smart switch
Old 07-11-20, 10:41 AM
P
So I've been putting in a few Kasa smart switches here and there, as they've been on sale quite a bit lately. And if you are installing a switch in a single gang box, it works great, the cover they come with is built to fit flush and perfect. The problem is that all the places I put them are in double or triple gang boxes with other switches. The plate covers fit ok, but because the backing on the smart switch is so thick and sits up against the drywall, it doesn't allow the cover to sit flush with the wall. It looks pretty ghetto in places. Here is a pic with a slight example. Any way to do this so the cover sits flush? (sorry, the light switch is not from and center, didn't frame the pic very well)
Old 07-11-20, 10:44 AM
Received 904 Votes on 844 Posts
It looks like the box is not sitting flush to the wall. With some switches it needs to be just short of the wall. I've noticed that some electrical plate have a deeper reveal allowing them to cover better and not leave a gap.
Old 07-11-20, 11:40 AM
P
Well the box is flush with the wall. If it were recessed a bit, maybe I could cut out some drywall and make the switch sit back further, but that's not a possibility. And I can't seem to find any deeper covers at local hardware stores.
Old 07-11-20, 12:14 PM
They're made like that so if used in a metal box..... the flange is still enough of an antenna to communicate with the hub.
Old 07-11-20, 12:15 PM
Tolyn Ironhand's Avatar
Received 169 Votes on 151 Posts
Why would manufacture make a device with a yoke that thick?
I would find a different switch
Old 07-11-20, 12:26 PM
P
Ha I would but they're awesome switches, work with alexa, no hub required, and they go on sale for about $15 a pop sometimes. I'd rather try to deal with this than a subpar switch.
Old 07-11-20, 12:32 PM
You can try some other brands of switch plates. They may cover better.
Old 07-11-20, 04:33 PM
Yes.... correct but they still need to transmit and receive.
Many RF type devices don't operate well in a metal box with a metal plate.
Deep decora plates
Old 07-11-20, 05:40 PM
P
Yeah I'm not sure where a metal box came into the conversation. I know they need to transmit and receive, they're not in a metal box. I'll look into other types of plates. A couple boxes in my house were recessed enough I was able to slice out a bit of drywall so they could set back again the box and they worked fine. Just the ones that the box is flush with the wall don't seem to work.
Old 07-12-20, 06:12 AM
Geochurchi's Avatar
Received 56 Votes on 52 Posts
Hi, have you tried metal switch plates ? they maybe a bit deeper.
Geo
