Induction lighting
Old 07-20-20, 09:54 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Induction lighting
Hi All. Anyone familiar with induction lightIng? We have 6 pole lights that need lamps, I just found out they are induction lamps, never heard of them before, are these lamps interchangeable or does the power supply have to match the lamp?
Geo
Old 07-20-20, 10:21 AM
Received 3,422 Upvotes on 3,068 Posts
Induction lighting uses a lamp with gas in it and high frequency magnetic waves to stimulate the gas inside the bulb. The bulb type would be very similar to fluorescent.
I haven't heard much about induction lighting recently. I'm thinking that LED technology may have overtaken it as a more energy efficient choice.
Old 07-20-20, 10:27 AM
P
Received 1,768 Upvotes on 1,581 Posts
I don't think I understand your question correctly. Everything works together as a system. So, yes and no. Yes, the lamp parts are interchangeable... with the correct parts. No, you can't substitute a incandescent, fluorescent or LED bulb for a induction bulb.
Old 07-20-20, 11:25 AM
Sorry.... I wasn't clear. I didn't mean to swap in an LED bulb.
I was referring to converting the fixture over to LED.
That would mean removing the induction frequency generator.
Old 07-21-20, 07:12 AM
Geochurchi's Avatar
OK, so the discussion has been made to scrap the induction system , approximately 8 poles 2 heads, lookIng at solar based on the fact that one of the poles the feed is compromised and would be quite entailed to replace.
looking for recommendations as to manufacture’s.
Geo
Old 07-21-20, 10:34 AM
Are you referring to outside fixtures ?
If yes.... I'm not sure how much effective light you'll get from a solar fixture.
That would depend a lot on the type of fixture.
Old 07-21-20, 11:57 AM
Geochurchi's Avatar
Theses are pole lights along a short roadway, the plan is now to contact a couple of companies and have put proposals together and we will go from there, I was just looking for any recommendations on fixture mfg.
Geo
Old 07-21-20, 05:03 PM
Kichler makes the best outdoor light fixtures if you're not on a tight budget.
Kichler post lights
The only solar post lights I've seen in use are Gama Sonic. Don't know much about them.
