4 black; 4 white and a ground coming from Ceiling Receptacle.
<img src="https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/80081ce4_7d68_4780_b011_298ea91cedc7_41f993cb118669633e5748faf1d4a946a4b446e0.jpeg" width="1128" height="1504"/>
<img src="https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/d0a22bc1_2049_4da4_8cc3_b93e40c5581f_e54c30bfb4c76dc6bde32478619e68ec2ef9428d.jpeg" width="1128" height="1504"/>
Hey guys, I had an issue with a fan in a bedroom which would not operate from the wall switch. The fan would only op with the pull-chains.
I’ve pulled the fan down, and what I see are 4w and 4b wires coming from the box. There are two cables on one side, and two on the other. I’ve located the single “hot” black-wire. I have no idea how to identify the switch loop. The red taped wire is the “hot”. Please help.
Any picture of how things were hooked up before you removed the fixture? How have you determined you have a switch loop?
Welcome to the forums.
Not sure what this means as you have pictures posted.
I do see a problem there as grounds have been cut off at the jacket.
Take the fixture bar down as it is not for fan use and post another picture.
That is not a fan rated electrical box either.
I see some uneducated handyman work here.
I sent a PM, but will reply on here now after I figured out how! Lol
Alright, I will remove the plate and take more pics in the morning! As far as the wire nuts inside the box, it appears they called the “neutral” whites, however I’m unsure.
This “dilemma” was discovered when the former ceiling fan didn’t work. I thought the issue lied within the fan motor itself, until I cracked the fan open and found all of the internal electrical components melted within.
At this point, I’m just trying to make heads or tails out of what the heck is going on.
** disclaimer: my wife and I just purchased this home in June and are finding all kinds of wonderful DIY “home-hacks” gone wrong**
No problem.... we'll help you out. It would be extremely advantageous if you had a test multimeter. A basic analog meter from one of the home improvement stores for $15-20 would be all you needed.
