Old Fluorescent Fixtures
Old 08-03-20, 08:42 AM
B
Received 13 Upvotes on 9 Posts
Thinking of buying some old fixtures then install LED tubes. I think I can just remove the ballast and rewire, I do have new tombstones if that matters.
Here are some pictures....
2 Rivers Auctions
I don't know if these have starters, not sure that would matter with rewiring?
Ideas appreciated, thanks.
Old 08-03-20, 10:15 AM
D
Received 9 Upvotes on 8 Posts
Those had better be almost free. I would not pay more than 5 bucks each.
Removal of the ballast is not necessary on some LED replacement lamps. I bought my lamps at Costco some years ago and changed out the lamps in my garage. I can see now.
Food for fodder,
https://www.lightup.com/led-4ft-shop...00050156-4000K
Old 08-03-20, 10:51 AM
Received 74 Upvotes on 69 Posts
Those look like those old "Lights Of America" (Made in China) style of fixtures they were only around $19 new I would not even bother with those at all the metal is paper thin and bends at the drop of a straw. Find an old made in America Quality fixture. I have LED with a passion but I am not the one paying your electric bill so do as you please.
Old 08-03-20, 12:18 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, $2.00 tops, how do you plan on powering them up ,draping cords ?
Geo
Old 08-03-20, 01:46 PM
B
These will be in my pole building way up near the ceiling, receptacles on each side so just plug them in. Right now there are those lights with a two little ~6" tubes, forget the name but they don't work anyway.
Like my other garage I'll use Hyperkon 5000k tubes. Don't remember what they cost back then but $8 a tube is much better..
Could anyone tell me the thin wire used after the ballast to each tombstone? Much smaller than #12, I'd like to replace it all after the cord.
Thanks
Old 08-03-20, 03:05 PM
The wires that go to the sockets (AKA Tombstones) is 18AWG solid wire. If the existing is in good shape I would reuse it (That is what I do every time I toss a dead ballast I save the leads if they are in good shape). As I stated I hate the LED movement but I don't pay your bills. I would get those ballast bypass tubes and follow the diagram on how those ones are connected to AC power use the 18AWG wires from the sockets and wirenut it to the fixtures power cord also don't forget the ground wire.
