Switching from dimmer to regular light switch (newbie)
Old 08-03-20, 09:48 AM
C
I installed a ceiling fan and do want to NOT have a dimmer light style switch due to lots of humming in the wiring. I am confused as I have two black wires to contend with and the white wires are tied together. The new switch just has three screws, I assume white, black and ground. I am confused which one of the black and white wires to use or use both?
<img src="https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/img_4613_06d53ac67fce34c2d11917114facc9254a9b6808.jpg" width="1128" height="1504"/>
Old 08-03-20, 10:03 AM
Z
Received 422 Upvotes on 375 Posts
The two black wires from the old dimmer get connected to the brass screws on the switch. The whites remain as-is. Ground goes to ground. It's that easy!
Both wires into and out of the switch are black because it's hot in and hot out.
One white wire is a 'return' from the fan, and the other white is the return back to the panel. Neutrals are never switched.
Old 08-03-20, 12:33 PM
C
Does it matter which black wire goes to which post? The posts on the new standard switch are brass and silver color.
Old 08-03-20, 06:56 PM
Received 3,976 Upvotes on 3,569 Posts
No...... you can put either wire on either screw terminal.
Old 08-03-20, 08:26 PM
C
Got all hooked up and works great! Thank you so much.
