Bathroom Light Fixture Replacement with Al Wiring
Old 09-01-20, 11:27 AM
E
Replacing bathroom light fixture. Removed old fixture that was connected with existing Aluminum house wiring. House was pig-tailed with certified company but they didn't mention that they weren't doing this fixture, probably because it was hard wired and not easy to get to. Since I am replacing fixture with new one, im wondering if I can get away with using the Ideal twister for AL-Cu wiring that HD sells. Thx for any input!
Old 09-02-20, 12:28 AM
Received 3,880 Upvotes on 3,477 Posts
If it's a low current draw light..... like an LED....... those wirenuts will be ok.
Old 09-02-20, 07:45 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Hi, you could cut the old fixture wires close to the fixture and reconnect them to the new furnace with regular wire nuts and don’t disturb the Al. connection.
Geo🇺🇸
Old 09-02-20, 11:26 AM
Z
Received 414 Upvotes on 368 Posts
Instead of the purple Twister nuts, I would rather use Alumiconn connectors. They are a bit more expensive, but the connection is much more secure and reliable and don't have the issues that the Twister nuts have.
I would personally never use the purple Twister wire nuts ever. There are better solutions out there to use a product that has questionable reliability and safety.
Old 09-02-20, 12:50 PM
Geochurchi's Avatar
Deleted *****************
Geo🇺🇸
