Bulb help?
Old 09-04-20, 02:58 PM
A
Bulb help?
If my fixture just says Type B can either B10 or B11 be used? B10 was replaced with B11 recently and want to make sure what he did was ok!
<img src="https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/1ecff194_7f60_4419_bc20_b9f423eaa670_2a0d51a79af6fdd632e5f860744e3d20f8b9266f.jpeg" width="1128" height="1504"/>
Old 09-04-20, 03:34 PM
P
Received 2,180 Upvotes on 1,950 Posts
If it screws into the socket and physically fits and is less than the maximum wattage for the fixture I use it. With an LED bulb like you have wattage is usually not a concern so if it fits and works I'd stick with it.
Old 09-04-20, 03:46 PM
P
Received 5 Upvotes on 5 Posts
Yep, the number merely refers to the diameter, in eighths of an inch. So if it fits, the slightly larger bulb is fine. Despite the label, you could use a shape other than B blunt tip too. I suppose it's possible that a different shape or larger lamp could have slightly different thermal properties, but it's not likely to make a difference from a safety perspective in most cases. If it's LED, like this one, then it certainly doesn't matter.
Old 09-04-20, 05:00 PM
A
Thanks!!! My main concern is safety and not having a fire hazard
