outlet wiring to switch
Old 09-19-20, 08:29 AM
G
I have a couple of rooms that don't have ceiling lights, I know that you can plug light fixtures in wall and turn them on with light switch. I have done that, but they will not turn on, could it be wired wrong in one or the other
Old 09-19-20, 09:58 AM
Received 3,420 Upvotes on 3,066 Posts
Not totally clear.
You have wall switches with no ceiling lights.
Is there a blank cover in the center of the ceiling or nothing at all ?
Usually if there is a switched duplex..... one receptacle is always live and one is switched.
Have you checked every receptacle.... top and bottom ?
Old 09-19-20, 12:06 PM
Received 477 Upvotes on 393 Posts
If you had a half switched receptacle and someone changed it without cutting the tab on the hot side, the switch would no longer work.
Old 09-19-20, 07:44 PM
G
There is nothing at all in the ceiling, just the switch on the wall and will not light up any lamps that i put in the rooms
Old 09-19-20, 07:51 PM
That's why I mentioned this post was not clear.
What you are saying is that some or part of a receptacle is not working if "they will not turn on".
Do you mean that all receptacles are live and nothing shuts off with the switch ?
Old 09-20-20, 07:06 AM
G
the outlets are all live, I don't know if the switch on the wall is live, that is why I am asking if they are wired wrong and if I have to change them around to work.
Old 09-20-20, 08:06 AM
If you had a half switched receptacle and someone changed it without cutting the tab on the hot side, the switch would no longer work. All the receptacles would be live always.
Old 09-20-20, 01:53 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Hi, did they ever work, did you replace anything?
Geo🇺🇸
Old 09-20-20, 02:02 PM
What you would need to do now is turn off the circuit that controls the receptacles. Pull them out one at a time without disconnecting any wires and see what wires are connected to the receptacles. You could describe each location or post a picture of it.
Old 09-21-20, 03:42 PM
G
no, they never worked with the wall switch, that is how they were when we moved in. The outlet it self, works with a lamp plugged into it, and I have to turn it on and off on the lamps.
Old 09-21-20, 05:59 PM
Third try
