T8 fluorescent workshop light not working
Old 09-24-20, 11:37 AM
D
hello
i have a workshop light
2 T8 fluorescent bulbs 48"
the lights were intermittently flickering for a few months and now everything is dead.
is it safe to assume its the ballast?
also just curious
what is the current preferred type of lighting for workshops/garages etc
still T8 or is it now LED type?
Old 09-24-20, 11:39 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Dont even consider replacing that ballast, throw it out and get direct wire LED's you will never regret!!
Old 09-24-20, 11:46 AM
P
Received 2,009 Upvotes on 1,801 Posts
LED all the way. Buy the direct wire (120VAC powered) LED replacement bulbs like Marq1 mentioned. I converted my factory, warehouse and office a couple years ago and would never go back to fluorescent.
When you get your bulbs make sure you read the directions. There are two types. One type you run hot and neutral to the pins on one end of the bulb and nothing to the other end. The second type you wire hot to one end of the bulb and neutral to the other. Both are easy to do, they are just different and not interchangeable.
Old 09-24-20, 04:53 PM
Marq1's Avatar
Only issue, if you have a radio/stereo in the vicinity, reception is toast, I have tried several antenna variants and nothing resolves, I now listen to CD's with the lights on!
Old 09-24-20, 05:40 PM
Tolyn Ironhand's Avatar
Received 811 Upvotes on 683 Posts
That's odd. I have had the exact opposite experience when I converted my ship T8 lights to LED. I now get zero interference from the LED lamps.
Old 09-25-20, 05:21 AM
P
That is odd. I have never had any issues with radio reception and LED lighting.
Old 09-25-20, 07:01 AM
Marq1's Avatar
Electro Magnetic Interference, or EMI, can be a big problem and is largely due to the fact that the LED power supply is switching at some rate to turn the supplied AC voltage into a DC voltage.
For some reason all the LED lights in my garage effect the stereo I have out there. I sort of suspect since they are on the same circuit that may have something to do with it since nothing else in the house is affected,
Old 09-25-20, 09:39 AM
Received 77 Upvotes on 72 Posts
I only use fluorescent lights and mine have commercial grade electronic F32T8 ballasts (FCC non-consumer limits something or other). those ballasts really kill any FM & TV reception in my small apartment.
