Adding a light to a 3-way switch
Old 09-26-20, 10:41 AM
B
At the bottom of my stairs, I have a 3-way switch with only three wires going to it: red and white travelers and a blue common. There is no neutral. Is it possible to connect a light to that switch?
Old 09-26-20, 10:44 AM
Received 3,898 Upvotes on 3,494 Posts
No..... since you don't have the needed neutral there.
You said blue wire..... does that mean you have a conduit system ?
You may be able to pull a neutral wire in.
If it's a cable.... it's red, white and black.
joed voted this post useful.
Old 09-28-20, 11:37 AM
B
Thanks. That's what I was afraid of.
Old 09-28-20, 07:51 PM
You didn't answer my question..... is this a conduit system or did you mistake black for blue ?
If it's a conduit system you may be able to run a neutral wire thru the conduit.
Old 10-06-20, 01:33 PM
O
I installed a wrieless switch to make it a 3 way switch.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
