Exterior flood lights, not flush mounted
Old 09-26-20, 07:07 PM
C
Received 30 Upvotes on 28 Posts
I've got a few exterior motion sensor flood lights where the junction box is mounted to the exterior wall face. Looking to replace a couple of these as the motion sensors have gone bad (these are 20+ years old).
<img src="https://i.imgur.com/P0wwKXT.jpg" width="3024" height="4032"/>
<img src="https://i.imgur.com/tBcVON3.jpg" width="4032" height="3024"/>
All the flood lights at Home Depot seem to be designed for a junction box that is flush to the wall, such that the light's junction box cover sits against the wall. For example, this light
<img src="https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1000x1000/white_defiant_flood_lights_dfi_5412_wh_64_1000_55b21ccd413244098c833c27879cda7ca384343d.jpg" width="1000" height="1000"/>
If I use these, they should overlap the junction box, but I guess water will be able to get in from behind unless the overlap is very small and I can seal it with silicone caulk. If I could get it sealed, in terms of color matching, I could spray the light fixture parts with silver spray paint. From a distance, that would look good enough.
Other options?
Old 09-26-20, 07:35 PM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
You can remove the lamp holders and the sensor from the white plate, and install them into the old plate. There appear to be enough knockouts.
Andy
cartman voted this post useful.
Old 09-26-20, 07:52 PM
Received 3,892 Upvotes on 3,489 Posts
Or you can buy new plates. They come with multiple ko's.
The same 4" round weatherproof plate fits flush mount or surface boxes.
You can buy a kit that comes with two fixtures, a plate and a motion sensor.
<img src="https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/207x207/4_wpbox_de69a1872323afa96b187da72f05803423b34072.jpg" width="207" height="207"/>
Old 09-26-20, 08:30 PM
C
Thanks, I found those plates, seems everyone sells the same one, made by Progress Lighting, though prices vary wildly. Amazon reviews suggest the threading is not quite to the correct spec.
https://www.amazon.com/Progress-Ligh.../dp/B01AS7YHUS
Might be easier to use the existing plates as @Andrew suggested. The existing plates are so old they might actually be made in America.
The motion sensor light I linked to earlier runs $28 at Home Depot. But I guess the only part I really need is the motion sensor since I can use existing plate and light fixtures (and if I'm using the existing plate, I'd rather use existing light fixtures since they color match). Also need gaskets, but I guess I can find some kind of gasketing material and cut to the correct size and shape.
Anyone know where I can get decent motion sensors that don't cost almost as much as the entire assembly at $28? There's always ebay and chicom stuff (which I guess all motion sensors sold in America originate from), but don't want to have to replace every couple of years.
Old 09-27-20, 01:06 AM
RAB makes the best motion sensor but it's not the least expensive. Nowhere near $28.
