Garage light
Old 10-25-20, 04:46 PM
Garage light
My garage light quit working my husband changed the wall switch which has 3 switches one for garage one for kitchen light and ceiling fan in kitchen, it still didn't work so he got a new light fixture and installed it, it only has 2 wires plus the ground wire he hooked it up the same way as the old but still not working. Any help please.
Old 10-25-20, 04:48 PM
Received 821 Upvotes on 720 Posts
Did he take a multi meter and verify there is voltage at either the light or the switch?
Old 10-25-20, 05:16 PM
Garage light
no tools like voltage meter he's no electrician, just thought it would be one of the two. Thought it would be a simple job, only lived here 3 yrs.
Old 10-25-20, 05:22 PM
Received 3,877 Upvotes on 3,475 Posts
If the other switches work.... then you probably have power there.
You eliminated the switch..... assuming it's not a three way circuit with two switches.
Did he use a new bulb in the light fixture ? If not.... check the bulb in a working fixture.
Outside of that.... he'd need a way to check for voltage. Either a basic meter or voltage tester.
