Ceiling fan junction box?
Old 11-07-20, 07:20 PM
K
<img src="https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1500x2000/ee6587f2_7ff8_4877_8ec7_caa3f1bba003_d9bfcf37915d585946ebec2ec74a28ed3b69623c.jpeg" width="1500" height="2000"/>
Hi, Iím hoping someone can help me figure out if this junction box would be compatible with a ceiling fan? The only thing I can find on it is the number 3090 when looking at it from below.
Old 11-07-20, 07:31 PM
Received 3,996 Upvotes on 3,586 Posts
Welcome to the forums.
No.... I would not consider that a fan rated box since it's only nailed to the joist and uses rivets.
I would replace that box with a side mount smart box or a 4" screw on box that has a welded mounting bracket.
<img src="https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/809x190/fb_308db9db9ac82e6b6f78b1703768868bb84e21e9.jpg" width="809" height="190"/>
Your box is rated up to 50 lbs of static load..... not a fan load.
Carlon 3090
Old 11-07-20, 07:37 PM
XSleeper's Avatar
Received 1,924 Upvotes on 1,728 Posts
I would add that since you have access from above, simply remove that junction box, put a piece of 2x6 blocking at the right height for your box (between your trusses / ceiling joists), fasten it one each side, then you could use any screw on box above.
Old 11-08-20, 05:32 AM
K
Ok. Thanks for all the info and help identifying it.
