Combination switch trouble
Now that I'm writing this and I drew out the configuration that I have I think I know the problem but I need to ask because not terribly sure. I am wiring 2 lights and am using one of these: Legrand: Combination Device, Duplex switch model 690. Now in theory I should be able to have a single power source in and then the separate switches control the separate lights. I have attached a very bad drawing of the configuration the circles are lights lightning bolt is the hot wire(s) dotted lines are e white wires and of course green is ground. Now it will allow me to power one light at a time but not both. Any thoughts will be greatly appreciated, just try not to laugh at me to much.
<img src="https://cimg3.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1171x686/lights_93146df5145303ebe539f349a572fc4e0652c8cb.png" width="1171" height="686"/>
White wires do not attach to the switch. One side of the switch will have two screw that are connected via a tab between them. You connect the power to one of them. The other side has two separate screws where you connect the light hots.
I had that originally and nothing worked. The problem i run into is the power source for the one light comes FROM the light (old house wiring nothing makes sense). When i complete the circuit for the one light without a switch the light works, when i connect the circuit with the other light without a switch and the hot wire the second light works. The problem lies with the fact i need the switch and am being stubborn and wanting to use the switch I have instead of just using 2 separate switch's.
I did not notice you only have two cables into that box.
Is the second light an new light? If it is then you can not do it. You do not have a neutral in the switch box. The first light is a switch loop. You have a hot wire from the light and a switch hot wire going back. The white is being used as a hot not a neutral.
The second light has to connect to the first light or you need to bring power to the switch box instead of the light.
I'm not following.... was there one switch and one cable originally ?
If yes..... the second cable is your new cable ?
and just run a jumper of the hot wire from one to the other?
