Questing about Grounding Wire for Fixture Mounting Bracket
Old 12-30-20, 11:43 AM
C
I am replacing a bunch of light fixtures, and they all have a mounting bracket with a grounding screw. This is probably a dumb question, but can I use the grounding wire from the metal box, wrap that around the fixture ground screw, and then tie that to the main/incoming ground with a wire nut? Or, is it better to have three separate grounds (one from the main, one from the box, and a separate one on the fixture mount)?
Old 12-30-20, 12:00 PM
Received 3,982 Upvotes on 3,574 Posts
If you put that bar on a metal box that had no ground wire..... that screw would become your fixture ground location.
You can connect the incoming bare ground wire directly to the fixture ground wire.
Old 12-31-20, 07:51 AM
C
PJ, thanks. I guess what Iím asking is can I run a ground wire from the metal box ground screw, wrap that same wire around the ground screw on the mounting bracket, and then wire nut that together with the incoming 14/2 ground and the fixture ground. Is that the right way to do it?
Old 12-31-20, 05:47 PM
As long as all the grounds are connected together... there really is no right way.
What you are suggesting is ok.
Old 12-31-20, 10:34 PM
C
PJ, thank you. I really appreciate it.
