Flood Light install
Flood Light install
Hey everyone, I am trying to install some flood lights around the house. I wanted to confirm my plan with you knowledgeable folks. My plan is to have a total of 5 floodlights at 240watts each for a total of 1200 watts. I want to install a 15 amp breaker and run UF-B 12awg with ground from the breaker box to a junction box in the attic which will split into 3 12awg wires 1 going to a flood light on the front of the house and the other 2 going to separate junction boxes at each end of the house that split off into each remaining floodlight all using 12awg. Is this a reasonable way to do this? Should I change the wiring size?
Welcome to the forums.
Why not install LED floodlights or fixtures and reduce that wattage load considerably.
If you are creating a 15A circuit..... use #14 NM-b cable. You don't need UF inside the house.
You can even install surface mount boxes outside the house and bring NM-b in the back.
A junction box with splits in the attic is fine.
You didn't mention a switch anywhere. Usually flood lights have a switch inside, even if they are on motion sensors. You don't know when someone might want to turn them off completely. Not a specific code requirement, but just a typical installation. Of course, you could use one switch or 5 separate ones.
