Need help Connecting a motion sensor with my outdoor light
Old 01-10-21, 02:38 PM
I want to see if anyway I can put a motion sensor and connect with this light set for motion. This light will be front of my driveway. I see they have switch but those are plugins right into the outlet. I assume for this set I need to have the motion sensor facing the driveway and somehow have the wiring in-between the power and the light. I am using a contractor but he is not sure how to do this. So I am here for advice what I can do.
Here is the link for the light I want to use.
https://www.wayfair.com/lighting/pdp...periencetype=1
Old 01-10-21, 03:05 PM
Received 3,422 Upvotes on 3,068 Posts
Canopy/Backplate: 8.500"H x 4.500" W
That is basically a house mount. What are you going to attach it to ?
It's too wide for a 4x4 post.
Or are you planning on installing it on the house facing the driveway ?
Is there a box currently installed there ?
Old 01-10-21, 05:55 PM
C
Received 13 Upvotes on 9 Posts
I'm not sure what you can use as the motion sensor part but this can be done. I was able to link my ring camera motion sensors to trigger hue bulbs to turn on then off with the smartthings app. It was pretty easy that way.
