Bathroom light fixture
Old 01-22-21, 07:05 PM
D
First off house was built in 2005. We bought it in 2015 and noticed it soon after buying. 1 light on a 4 light fixture in bathroom would flicker and then go out fairly often . We have always used led bulbs. I figured a poor connection so I replaced the fixture and it seemed to work for a while. Now the same thing is happening again. What am I missing? TIA
Old 01-23-21, 05:08 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi, itís still one socket thatís flickering?
Geo 🇺🇸
Old 01-23-21, 05:24 AM
D
Yes. One still starts to flicker shortly after replacing it. It never lasts more than a few weeks. All other bulbs are good and are the ones I put in when I changed fixture.
Old 01-23-21, 06:39 AM
Norm201's Avatar
Received 725 Upvotes on 641 Posts
Experiment a little. Is it the same fixture of the four? What happens if you only use 3 bulbs? Switch the three bulbs from fixture to fixture. What happens if you use incandescent bulbs? What brand of LED's are you using, What happens if you use three LED's and one filament bulb? What else might be on that same circuit? Is there any possibility of a short or loose connect to that one fixture?
Old 01-23-21, 07:05 AM
Tolyn Ironhand's Avatar
Received 878 Upvotes on 741 Posts
Is the fixture on a dimmer? Does the switch turn on anything else like an exhaust fan?
