I have 4 wired together ceiling fans 18’ high in my great room and they are all set on high speed. Now, that’s great when it’s hot here in AZ, but I would like to slow them down and use them while I run the heat because the registers are up there and you can feel the heat circulating when they run, they just run too fast.
While I know you don’t use a dimmer switch, is there anyway I can replace the wall switch with something else? I’ve tried the pull the chain idea, but at 18 feet high, and it’s very small, I can’t acquire them. What other options do I have?
Steve
Fan control switches and smart switches are available that will allow you to set a fan at various speeds. You might have a problem finding one that can handle four fans at the same time. Make sure you check the capacity rating of the control. Your fan manual should have specifications showing the current or wattage of each fan. If you do not have the manual or manufacturer/model information you may have to look for a nameplate or label on the fan.
I believe your fans would normally switch from low to high speed with a pull chain. There's probably a separate pull chain for changing direction. Your best option is to get pull chain extensions.
When you pull the chain for speed change, a second capacitor is energized and it powers a second winding in the fan motor.
If you install a dimmer for the fans and set it at half power, your fans will likely spin at half speed. The fan motors may make a humming sound though. There is also possibility that the motor will run hot.
The fan manufacturer can give better info.
There are a few decent fan speed controllers.
Dayton and FanTech are two. The links below are for the 6A and 10A Dayton models.
I would think the 6A should be large enough.
Will they work for sure.... no way of knowing until you try one.
I am definitely concerned about a hum or heating issue. While I’m no electrical expert, it makes sense that the speeds are handled by progressively more winding in the stator, with the lowest speed using the fewest. While the highest speed, where it currently set, uses the maximum windings. Inducing a lower voltage should work; that’s how all of the older “speed” switches worked. That said, to complicate the issue, the 4 fans are wired with a three switch system. If I add a speed controller, would I need to do it at both locations?
What a three switch system ?
Is that three locations that control all the fans ?
You more than likely have two 3way switches and one 4way switch.
Three way switches will have three wires on them and the four way switch will have four wires on it.
A speed controller would have to go in its own box next to one of the three way switches.
I would try the controller first before installing a box for it or making it permanent.
No problem.... it's a three way switch system. I labeled your diagram. The two yellow dots represent where the speed control would have to be connected. It would need to be in either location..... not both. The style of fan speed controls I linked to don't operate as a three way switch.
Well, rats. That’s what I was worried about. Both of the boxes that hold the current switches are in 4 gang boxes and of course my luck, they are mounted, both, between studs in short length walls. I was hoping I could replace one or both with some 3 way switch, fan controller combo, but I couldn’t find one. It was why I ask the community.
I would think you could install a few of the controller I linked and then probably link them in the smart things app as a room or scene to link the settings or control them individually. I have done that with some lights.
My other option is to eliminate the “three-way setup” and use one of the switches and convert that to the speed control. So, based on the diagram, I’ve got to determine which one has the “source” power to it. Now, one of the switches is near the front door and one near the rear door to the backyard. Would it make sense that source gang is likely by the front door? Since both are 4 gang boxes, so many wires to fish through.
Also, if I’m lucky, and the box by the front door has the source power, what do I do with the other box beside remove the switch, cap all the wires and put a 3 for 4 gang box cover over it (covering the last gang position)?
Leave the unused switch right where it is. You can put the speed control in either place.
If you tell us what is on both switches we can fine tune this.
If your wiring is exactly like this diagram......
Connect black traveler together with common. Leave red where it is on switch 1.
At switch 2.... remove red and cap it off. Connect speed control to two remaining black wires.
This can be reversed to put the speed control at switch 1 location.
Thanks. I’ll be back in AZ next week, so I’ll remove the covers and take pics of switch 1 and 2 and wait for your assessment before I install the speed control. I want to order the controller; would it be “safer” to get the 10a over the 6a?
Yep, rats. I’ve found other “electronic” speed controllers, all claiming to eliminate any hum, but most of the low ratings cite a short life with two fans. 4 would kill one quicker. So, I’m left with the Dayton speed controller. Thanks for all the help.
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1500x2000/img_20210128_102434_01_02c2e1b325945a6fd0e5ae8ca7585e961bc67fd0.jpg[/img]
[i]Old ballast[/i]
[img]https://cimg9.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1500x2000/img_20210128_102451_01_a90b866f6939cd188f9f83337573e8f7616674be.jpg[/img]
[i]New ballast[/i]
I am replacing a ballast, I followed the wiring diagram and the lights came on, but the middle of the bulb is dim and the light itself seems wavy.
I connected the red wire from the ballast to the two yellows on the fixture. Then connected one blue from ballast to two blues on other side of fixture. Connected other blue from ballast to the two reds on fixture.
Again, light comes on but it's dim. Is it a wiring problem or is the new ballast just not suitable?
I really enjoy the look of these strung across the patio however I've never really seen it in a screen in patio enclosure. Has anyone here done it and how did it turn out? Pic below for reference
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/7f940ac9def4f9bf45c5942c0fe9a09f_4502289598c47718df076ebb6b39886592cb54fd.jpg[/img]
