4-way switch troubles.. using only 3 switches
Old 01-31-21, 10:10 AM
D
So I have myself in a jam with wiring I totally buggered up. Maybe some one can straighten me out.
I have a split level house. My switches are
a switch on the bottom landing (box 1), a switch on the actual landing (box 2) and a switch on the upper landing (box 3).. and they go to a single overhead light.
my issues comes in that box 2 has the power from the circuit and also goes to the light.
I have looked at a lot of wiring diagrams but haven’t found any that address my layout. I’m thinking that box 2 would be a 4 way switch and the top and bottom landings would be 3 way switches, it I have myself confused. Hope someone can straighten me out.
Old 01-31-21, 10:18 AM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
A three way system is two switches. A four way system uses three switches.
You must use two 3 way switches and an unlimited amount of 4 way switches.
Either post a picture of each box or tell us what colors you see at each box.
How-to-insert-pictures.
Old 01-31-21, 10:56 AM
D
Oh my..so sorry. There are 3 switches.. so that would be a 4 way correct?
will these photos be helpful.?
thanks so much Pete!
This is box 1, at the bottom of landing.. 3 way switch. I tested and there is no power
This is box 2. This has 3 lines in it. And 2 switches. One switch turns on/off outside light and works. One on the right has power. The middle one seems to go to both the outside light and the inside light(the one I’m trying to fix). And then the 3rd I don’t have connected and are red white and black.
This is box 3 top of the landing. There are 2 sets of red white and black in it. I tested and nothing has power
ill repost the pictures.. I think they were too big to upload
Old 01-31-21, 11:31 AM
D
Old 01-31-21, 11:36 AM
D
Hi Joed.. took a min, but just posted photos of my mess
Old 01-31-21, 01:57 PM
Received 477 Upvotes on 393 Posts
Box 3 is the 4 way.
Here is a new drawing of what I think you might have. Is that black wire with no nut at the top the light cable?
The black pigtail going out the bottom right of the image is your power feed. It goes on the common screw.
Old 02-02-21, 01:17 PM
D
Thanks Joed!
I got a little confused by your diagram.. Sorry, I'm not an electrical person.
But I found this and this worked.
Thanks so much for trying to get me straight!!
Old 02-02-21, 02:58 PM
That drawing is the same as mine except for a couple of wire colours swapped.
