7" hole saw for range hood
Old 02-02-21, 05:08 PM
Z
Even cheap range hoods now use a 7" round hole. (they also offer rectangular holes though). Unfortunately, I can only find 6" hole saws at home depot and menards. Where do I even find 7" vent parts for a range hood? Am I better off going with the rectangular vent installation?
Top Answer
02-03-21, 04:40 AM
Pilot Dane
Pilot Dane is offline
Received 2,311 Upvotes on 2,056 Posts
As the hole gets bigger the torque you must fight increases. Even a 4" hole saw can fight back pretty hard. If you do try using a 7" hole saw, especially in a tight space, make sure you use a drill with a clutch so it will let go instead of hurting your wrists. With anything 5" or larger I'm no longer even thinking of a hole saw. I mark the hole. Then drill a smaller hole at the edge. Insert a reciprocating saw blade through the hole then cut out the larger hole. It's about the same process you'd have to use if you decide to use a rectangular duct.
Old 02-02-21, 05:47 PM
Tolyn Ironhand's Avatar
Received 913 Upvotes on 771 Posts
Depending on the material you are cutting through, a drywall saw will work. Or you can use a jigsaw, reciprocating saw, or even a series of holes drilled with a smaller drill bit. You can also get an adjustable hole cutter. There are lots of ways to make a hole in a wall.
You can order a 7" hole saw online and typically Amazon will deliver in 2 days. Just be VERY careful! If that hole saw grabs you can darn near break a wrist.
Old 02-02-21, 06:43 PM
XSleeper's Avatar
Received 1,974 Upvotes on 1,770 Posts
Menards has an adjustable hole saw that goes up to 7". But it is kind of a piece of garbage. Good for drywall but thats about it. For one hole, I would just trace it, or use an old fashioned drywall hole cutter.
And 7" duct is a stock item at menards but some fittings might be special order. You just need to plan ahead for what you need.
Old 02-03-21, 04:40 AM
P
Norm201, Zorfdt voted this post useful.
