Add switch off of gfci outlet
Old 02-19-21, 03:38 AM
N
I want to install under cabinet lighting and was looking to follow the instructions found here (https://www.thisoldhouse.com/platfor...binet-lighting) but have a few questions.
1) is it acceptable to connect a switch to a countertop gfci outlet in this manner?
2) if it is, does anyone have a better diagram of the correct wiring?
thank you
Old 02-19-21, 06:01 AM
P
Received 2,219 Upvotes on 1,981 Posts
Which part of the wiring is causing you trouble? I must admit in the diagram you linked I would expect to see a low voltage power supply somewhere as that's usually not done by the switch.
Old 02-19-21, 07:18 AM
Received 518 Upvotes on 423 Posts
1. NO. Counter top GFCI circuit can only serve counter top receptacles.
