Light Fixture Protruding from Ceiling - Replacing with Canless Recessed LED
Old 03-06-21, 10:50 AM
C
I recently had an addition completed, and this required moving the dryer vent. When they did that, they ran it over the bar of the fixture box in my laundry room. Itís causing the light fixture to protrude from the ceiling and doesnít look good. Iím trying to think about how to best fix this. I was thinking about replacing it with one of the canless recessed LEDs. Itís a very small laundry room, so I donít think I need much. I just wanted to see if that should work or if there is a better option.
Old 03-06-21, 12:58 PM
Tolyn Ironhand's Avatar
Received 882 Upvotes on 745 Posts
Those thin "cans" are only as thick as the drywall so it would likely work fine. The only caveat is there can't be very many cables in the box. At most, you will likely only fit 2 two-wire cables with grounds
Old 03-08-21, 09:53 AM
Z
Received 422 Upvotes on 375 Posts
You could also possibly relocate the existing box/fixture. You'll need enough cable slack in the ceiling to move it a few inches one way or the other. I'd probably use an old work round box and let it just hang from the drywall as long as the fixture is light. Then some drywall patching.
Just another alternative if you don't want to go the wafer LED route.
